Can anyone please help an idiot?
I was messing about with my cui and I managed to overwrite the command macro for the Advance Steel Linear Sloped Dimension command with the basic AutoCAD one!!
Can anyone please tell me the macro for the Advance Steel one?
For reference the macro for Linear Horizontal is "^C^C_AstM16CommDetAddUCSLinearDim", so it will be a similar format to that.
Thanks in advance
Al
Solved by Sebastian_Eiche. Go to Solution.
I'm not sure, but do you only need the command?
It's _AstM4CommDetAddSlopeLinearDim --> easiest way--use the command and have a look in the command line.
But why you want to overwrite it, the AutoCAD dims are not usefull in AS
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Thank you very much for that, much appreciated!
I was trying to add the Autocad version of the command to the AutoCAD Dimension panel for editing basic AutoCAD drawings.
I thought I was successful, until the next time I tried using the Advance Steel version, because I had overwritten the macro for the command itself the command line was showing the AutoCAD one.
Schoolboy error!
Kind Regards,
Al
