I am quite discouraged on the automation abilities to batch/bulk process CSA models into data rich DWF files that can be used within Navisworks. I thought having to script / deal with popups / call upon nwcout in a previous app for Prosteel + AutoPlant was painful.... automating Advanced Steel is much worse.
The ask:
What is the easiest method to automate the generation of / export to Navisworks supported files and retain the data?
What I Have Tired:
Automating the generation of NWDs/NWCs en masse and at a high clip (I have NWDs generating as fast as their DWGs are being updated) via using the Navisworks API that calls upon roamer to process the files. When it comes to Advanced Steel models, I was hoping that with the proper object enabler installed that I could simply open the DWG within Simulate and export to NWD/C/DWF and have a data rich model. Not the case. I am not even able to see anything?! So I tried:
1: using AcCoreConsole (the preferred method to automate a headless AutoCAD), and and issue the 3ddwf command for each DWG. This didn't seem to produce anything, and I got an occasional crash of AcCoreConsole.. so I abandoned this approach..
2: attempt to automate the batch calling of the 3ddwf command for a number of DWGs that are opened/closed via scr file passed into an instance of AdvancedSteelLauncher.exe. So this can work, but because the 3ddwf command seems to always throw open the :Export 3D DWF" dialog, (seems to be no way to suppress.. and this seems to be the reason that the AcCoreConsole approach failed), one must rely on coding a bunch of window manipulation / closing code and/or leverage a 3rd party tool such as AutoIt. This is an extremely fragile approach and I'm hoping there is a better way.
Questions:
1: is there any way to perhaps use the AS API and export to Navisworks that way? I.e.: is it possible to call the 3ddwf command from within the api? Hopefully that would allow for a much less UI dependent interaction and the API would allow me to open/save to DWF? I can't find API documentation that makes this clear to me..
2: If #1 above isn't possible, is there a way to suppress the Export 3D DWF dialog? Setting filedia / cmddia to 0 has no affect on this and thus requiring the use of an UI automation tool to "fill in the blanks" that can't be done via scr, AND handle any error dialogs that should arise.
3: if #2 isn't possible, what options are left?
Bonus: how does the Export To Navisworks button in the Export & Import tab of the ribbon seemingly creates a DWF and automatically launches Navisworks silently? How can we do the same?
If anyone can point me in the right direction, that would be greatly appreciated.
