Advance Steel generally does not draw any weld symbol that matches what is defined as a Standard Weld. Check the defaults "Connecting Elements > Welds > Standard Weld Type (Upper)" and "Standard Weld Type (Lower)". These correspond to Weld Main and Weld Double in the weld properties box in AS. They were renamed in AS2016 but the defaults were not.
If your weld is a different type but still the standard size then AS draws the symbol but does not write the number on.
If your weld is a different size then AS draws the entire weld symbol.
You can also check the defaults Connecting Elements > Welds > Standard Weld Size = 6 normally, Drawing Labelling > General > Create Weld Symbols for Default Thickness = empty normally, Drawing Presentation > General > Standard Weld Size in Drawings = 6 normally.
The general note on the prototype for the standard weld is not intelligently linked to these settings so if you change them remember to edit the prototypes too.
I hope that helps.
Aleck Giles
Application Engineer
Graitec, UK
Aleck Giles, Structures Consultant, Graitec
LinkedIn
