This is only possible by using the numbering for selected parts. I would use the modelbrowser, here you could easily select the parts by using the shift key and then use the numbering button.
The rule for numbering is a wish for long time...lit's hope for it.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
![EESignature EESignature](http://autodesk.i.lithium.com/t5/image/serverpage/image-id/1272565i464DC3DC646B4F11/image-size/original)
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
