I've been fighting this issue for some time that i'm either not understanding or i'm doing something wrong. after i create the model, i select numbering and make a few selections then once a drawing is created i get the correct main piece marks for the column or beam, but the plates or other items attatched have....
p#internal1
p#internal2
etc.
how do i get rid of the (#internal)?
did i select something i shouldn't have? i just want something like (p1, p2, p3) for the sub pieces.
The "#internal" tag on your part numbers is a temporary numbering system. In order for your part numbers to be finished, you need to get your parts detailed, or at least processed onto drawings, then the #internal will be replaced with the sheet number that the part is found on.
paul,
That worked. its not really explained clearly in the manual.
its always the little things that tend to be the pain.
thanks for your help
