numbering tool palette
rclement
rclement
hey people still trying get use to advance steel,slowly but surely
ok my question is when you do numbering i would think you get your numbering tool palette
which i would think numbers all of your parts
ok cool. first how do you call it back?
or the list that it creates is in the document manager under list?
johnjmbennett
think you mean the data panel, that pops up after numbering.
try the ribbon , home tab, checking panel , should be bottom right button.
cheers
John Bennett
Asif_KhanF835R
Hi @rclement
This will bring what ur looking for-
Give a like and mark as solution if it's right. Cheers mate.
mick-CNF
The model browser is pretty good for displaying information.
You can add and remove the columns at the top to suit, edit some properties, display full model or only items visible, select multiple items by single part or assembly to isolate and so on.
If this information solves your problem please accept as a solution.
