Please suggest how to delete previous main part marks?
We have found "Delete part numbers" option. By using that option single part marks are deleted, but main part marks can't.
Solved by AntDrt. Go to Solution.
Hello !
you hav to switch with this button: (in the output tab) working similar as the bolt commutator.
This icon is for signle part mark:
This one for the main part mark:
and this for preliminary mark:
you hav to switch between them to use the "delete part mark" command for each mark you want
Be advertise; when you use the switch it deselect object in the model.
Hope it helps.
