Numbering positions from 1, 2, 3 and so on, without 1000, 1001,...
radic_dominik
radic_dominik
Greetings experts,
I have a problem with numbering, especially with numerical order. What I want to have is positions in BOM from 1, 2, 3, with the same beams and other parts in alphabetic order.
I wonder:
- I don't know why they don't go in the order of 1,2,3…XX? It looks a little messy like this.
- What is the difference between pos 1 and pos 1000 or 2 and 1001?
- 1004 and 1005 are the same positions in my opinion. Why did AS separate them for me as individual positions?
I understand that there are single parts and assembly parts with their numbering method (SP 1000, 1001; MP 1, 2).
How to set that both SP and MP after numbering are set in order with positions also in alphabetic order of beams in the description from 1, 2, 3, etc., and without 1000.
Is there a solution for this situation?
I am attaching the AS model in the 2024 version if anyone wants to play with the numbering.
bigcarl5000kg
Hi @radic_dominik,
depending on the settings in your model, your numbering method is not set to what you require.  You must understand how the basic numbering (rules) work.
Here a small help (to learn something basic) - here I will explain how the selected numbering method affects the result (you will find there also answers for your questions):
https://advantage.graitec.com/en-CA/knowledgebase/article-details/?code=KA-01616
Next source:
https://help.autodesk.com/view/ADSTPR/2022/ENU/?guid=GUID-BBFD261F-DA8E-47AF-9028-D7E0073815DA
You will eventually find a lot of material for numbering on YouTube.
Try to understand what the numbering means for MP - all parts firmly connected to MP have the same MP.
For your purpose, you have to choose a setting without a method (none). I recommend using different numbering for SP and MP (e.g. SP from 1 - xxx, MP from 1000 - xxxx, or otherwise suitable).
In the attachment, I am sending  your model back with adjusted numbering, as an inspiration. Look at the numbering for SP and MP in the Model Browser.
HTH
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
radic_dominik
@bigcarl5000kg
This is explained in very detail.
I supposed that for my situation I should use numbering without a method (none).
I will use this as best as I can and make something practical and satisfactory.
Thank you very much for this information.
Best regards.
