Hello, I wonder if the Advance Steel is possible to configure the order of numbering. For example, the pieces would be marked in accordance with the location in the model, from bottom to top or from left to right.
Is this possible? How to configure?
I thank you.
hi,
is not possible, advance gives the numbers based on the profile, volume , holes cuts etc etc.
You can only make your personal touch in the numbering if you make a selection from a part of your model, or make more phases or give a personal note in the " free remark" line (if you set the selection box on it gives an effect on the numbering).
When you make selections you can for example starts with single parts on nr 400 and assemblys with nr 1, the secons selection you start with 500 and 100, 600 and 200 and on and on.
good luck
