Numbering on cut lists
I'm probably missing something obvious here butI keep hitting brick walls trying to fathom this myself...
When i produce a cut list for the shop floor e.g. 'saw list with pictures', the main parts of the assembly are labelled on the cut list as the assembly number and NOT the individual part number.
What do i need to do in order to display the all the individual part numbers for beams on material lists?
Sebastian_Eiche
if you open the BOM Editor and choose the list cut list, then you could change the field by a right click on it. In the context men, there should be a point called "field content" (sorry I have the german version, I'm not sure how it's really called).
If you choose this, there is the possibility to change what token should be shown, I suspect, the field content is "Posnumber", but there are 3 different token(singlepartnumber, mainpartnumber and posnumber), if you want to see the singlepart number, you hat to change the token to "singlepartnumebr".
If you choose posnumber, the field will show you the mainpartnumber, if the part is a mainpart, if the shown part is only a component of a mainstructure, the singlepartnumber ist shown.
I hope this helps
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
