公告
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Newbie please help Bom list not working
不适用
2,283 次查看
4 条回复
1 条消息(共 5 条)
不适用
Have trial version at the moment, finished model and trying to rum bom but get the following error. Anyone help?
No matching base objects found. Please check the selection definition. If the property \"class\" is switched on, a value (beam, plate,..) is required".
0 个赞
已接受的解答 (1)
2,284 次查看
4 条回复
回复 (4)
2 条消息(共 5 条)
yurikim
Please try the following steps:
  1. Go to Create lists
  2. Select the complete model > Next
  3. Select destination file > Create lists
  4. When Template Editor appears > Select the list in the template tree > Use
  5. Select the model extract for the BOM > Select the target list (List created in step no. 2) > OK
In which step do you see the warning?
If this doesn't help, please upload your model and BOM template you are trying to extract. Hope this helps.
Cheers,
Yuri Kim
Product Support Specialist, AEC
0 个赞
3 条消息(共 5 条)
不适用
The error comes up after number 3 pressing create lists. I have tried on other models and same thing happens. See attached model. I only need a material list from it so if I could get that I would be happy for now.
0 个赞
4 条消息(共 5 条)
yurikim
已接受的解答
Thank you for your reply. Have you checked this?
But if you have checked the option "Based on assembly", you should have assembly in your model.
I have noticed that Assembly numbering was not activated.
Check this and try to run the numbering again. Please let me know how it goes.
Yuri Kim
0 个赞
5 条消息(共 5 条)
不适用
It works, thank you but not sure what I was doing, I need to see how assemblies etc work
0 个赞
