Hi @markhubrich
To continue now with the small channel - s1012.
The situation is tricky, it seems to be a bit outside of "normal" expectations for NC viewers and NC machine.
Where is the "unusual": the 2 shorten features from each beam end are intersecting each other, and cut the bottom flange completely.
I am not even sure if a NC machine knows how to handle this, if the two cuts can be done by the machine. It might worth having a discussion with the NC machine fabricator.
When I check the NC file, I see that the web contour is correctly described. Also, if you open the DXF file, it looks correct. (see attached the DXF file).
When open the NC file with the ProCAM lite, it shows a small "something" from the bottom flange (see image). I do not know why, it does not make much sense.
When I open the NC file with Steel Project CAD viewer, it shows the entire bottom flange, in a different color:
Perhaps it knows a bit more on how to handle this situation.
Instead of a conclusion, I can only say that:
- the NC file seems to be correct, from the DSTV-NC Standard side.
- I do not know if this piece can be executed in reality. It might be a very good idea to discuss with the NC machine producer.
Please let me know if it helps, and if there is anything else I could assist further.
Best regards,
Emy
Emy Nestor
