.nc1 file Member Orientation
markhubrich
markhubrich
What is the determining orientation factor when these nc files are created? My drill operator is telling me that my beams are backwards. During his quick check process he compares the running dims from the detail to what his screen shows at the machine. I would like the left end in nc file to match the detail left end.
Here's what the drill line sees...
...and fix the kiss export issues.
johnjmbennett
The NC setting out is controlled by how the element is modelled,  when the beam is modelled, it has a start and end internal reference.
if I recall correctly, the start point in the model is the origin in the NC.
although you can change a detailing direction for drawings, this does not alter the NC output.
Sure there is a thread on this previously, also an idea to change this , to have the NC origin changed by user control to match the detail direction.
Check out this post, Emy explains in post.
https://forums.autodesk.com/t5/advance-steel-forum/nc-origin-point-can-it-be-moved/td-p/6030331
John Bennett
markhubrich
Thanks @johnjmbennett  It looks like I need to be in the habit of paying more attention to the start and end of my beam creation. This would be difficult to control on those jobs where I import members from Revit. Sometimes I import IFC from SDS2 also. Since this cannot be changed, is there a way to specify the assembly CS to always follow this orientation? If this is how it is and the beam gets modeled before it gets detailed I want my details to match orientation of my nc files.
johnjmbennett
So don’t shoot the messenger , but
From 0,0,0 in the x direction looking on plan with positive to the right in x , y vertical.
Model the beam from right to left, start at 0,0 end minus 30’ in x.
And before you say it, I know it impossible to be that regimented , many times this has cause issue with shop.
They got round it with drawings with detail direction tools, but no option for NC CS/ internal.
This blog entry may help explain:
https://graitec.co.uk/blog/entry/how-to-find-the-start-point-of-a-created-beam-in-advance-steel-2018
One possible solution, use a post process MIS tool to change start and end, another use one of the Step exports tools available from several dev partners of Autodesk.
John Bennett
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
