NC File - Wrong orientation of holes on folded plate
I'm having problems with the output of NC files, especially with folded plates.
It seems like the plate dimensions and the hole block are using different coordinate system...
Here's an example, the DXF file is correct but the NC file has the plate turned sideways 90 degrees and the holes remain in the same position.
I get no errors or warning when I output the NC files and I can't seem to figure out what is going on.
Thanks for your help.
Correct DXF file :
NC output for the same part
