Drawing style manager
dusanduckinoski996
Message 1 of 11
dusanduckinoski996
Once i tried to generate  3D drawing using drawing style manager and encountered on problem because my DSM looks totally different, anybody know why and is there and way to fix it? I am using AS 2022
Replies (10)
Message 2 of 11
acbsdesign
@dusanduckinoski996
Hold on, hold on,...how come you used one DSM but suddenly there is another DSM.
What happened overnight?
Any screenshots, or a model with details?
There is USER part of DSM and DEFAULT AS part (Drawings styles tool palette)-the one with the COUNTRY installation flag. Click on it and it will change to USER, if this is what you mean:)
Regards.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Message 3 of 11
dusanduckinoski996
Thank you for your invested time, dont have AS on this computer but i will link it in the moring when i come to work to show you what i was talking about
Message 4 of 11
dusanduckinoski996
Okay here is the thing. i was exploring a little bit. In DSM in Advance i tried to generate 3d drawing but didnt't succed because the tutorial i followed looks different, it seems it is different from country to country is there any way i can get DSM Advance from other countries. Here are some screenshot
https://prnt.sc/1qhoi08
Message 5 of 11
mehmet.ertem
You can install other countries packages. Then you will be able to reach that country's prepared DSM package.
Message 6 of 11
dusanduckinoski996
Thanks, i looked some tutorials but that only goes for advance steel 2015, can you link something where i could get those packages?
Message 7 of 11
mehmet.ertem
which country are you looking for? It should be in the setup I guess
Message 8 of 11
dusanduckinoski996
Not sure which one, but i want it to look similar to tutorial i watched so i will try a few of them
Message 9 of 11
dusanduckinoski996
Is there any solution to change DSM Advance to country which i want? Version 2022 is not working like 2015 when i open in control panel to uninstall/change program it isnt showing me the dialog to change country installation
Here is screenshot: https://prnt.sc/1qi1edr
                                   https://prnt.sc/1qi1xcd
Message 10 of 11
johnjmbennett
i think you maybe going down a slightly wrong route here,  if you are trying to create an additional view in any Drawing style irrespective of the country or language being set in the system,  the process is the same.
I do think you are in the English international version currently.
Also the way Advance Steel handles Country Settings and Drawing styles change in 2018 version:
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/video/youtube/watch-v-6vtoeR...
In this case a 3D view is possible to be added into the style,  and link to a drawing process.,  i made some notes and created a PDF file, uploaded below.
Also this is a video link to a quick overview of inserting a 3D view into a drawing style and process, based upon a column in the international version.
video link : Advance Steel adding a 3D view to assembly drawing
hope this helps out.
John Bennett
Message 11 of 11
dusanduckinoski996
Thank you very much, this helped me alot and i succed it, Your video is very helpful and explains alot of things, although now i have new doubts haha, but wont bother you anymore
