My thoughts about Advance Steel
MatthewAd
Message 1 of 66
MatthewAd
Hello everybody,
I started using ADS in Jan this year so I am quite fresh, I do however worked with Tekla for over 9 years now,
It is hard to transition and the most frustrating thing for me is the speed, speed of generating drawings, sections, details, etc. plotting is another one, that takes a lot of time. I also feel that when modeling, it is like your model is so fragile, any wrong move and you are in trouble. I hope my experience will improve but so far I am disappointed.
Replies (65)
Message 2 of 66
bigcarl5000kg
Hi @MatthewAd,
what was your reason for switching to Advance Steel?
Of course, it's a different world, but so are Tekla users very happy with Advance Steel too.
I would put it this way, give it not only time but also a chance.
If you lost a battle, you didn't lose the whole war.
You don't have the experience yet to make an conclusion.
Take it as a challenge and prove to yourself that you can do it.
We'd like to hear some news 🤜🤖🤛
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 3 of 66
MatthewAd
Don't get me wrong, I am not giving up, I have a whole year to improve so this experience will only get better.
If I can get to 80% speed of Tekla in ADS then I will be happy and will switch completely to ADS.
Message 4 of 66
EricOlson1973
I know what you mean about the model being fragile.  There are many ways to inadvertently mess something up, so it's best to set up precautionary measures.  Lock objects onto levels, lock your grid layer, etc.  It's also best practice to keep node as your only running osnap.  It helps you to be sure you're not grabbing the wrong point without having to zoom all the way in every time you click.
Message 5 of 66
MatthewAd
yes, that is true but what is going on with the gridlines? why the ADS crashes so often when you try to edit them?
Message 6 of 66
EricOlson1973
I haven't had issues with the gridline crash, but that isn't to say I haven't had my fair share of crashes in general.  I have learned to save quite often when using AS.
Message 7 of 66
bigcarl5000kg
Frequent crash can be connected with both SW and HW.
In my case it was e.g. user rights in Windows, GPU driver, ... Since then, it rarely happens to me.
Message 8 of 66
bigcarl5000kg
what are your most common, worst, unacceptable problems?
Message 9 of 66
MatthewAd
It definitely feels that it is easier to model in 3d view.
Message 10 of 66
MatthewAd
Modeling in 2d plane - very clunky. Drawing creation and section, detail creation in drawing mode - so slow, every time you create detail or section, it ends up flying off somewhere far away from the main view. Time it takes to create drawings and batch plot them, gridlines. Lastly, very often, when I am ready to plot the layout will change and mess my plot so I have to reset it by using window setting. Obviously this is just the stuff I can think of, while sitting in a pub and drinking beer.
Message 11 of 66
EricOlson1973
Modeling in 2D is much easier if you create and activate a level.  It ensures that everything will stick to the intended plane.
Also, if you aren't aware of the special gridline intersection osnap (it's in the right-click menu along with a couple other special AS osnaps), it is quite handy.
Message 12 of 66
bigcarl5000kg
I haven't used 2D modeling since 1998, when I used "3D" in Autocad for a lawn-mower model... 3D modeling is the only solution for me 😁😉
Message 13 of 66
MatthewAd
Levels, yes that will work but when you want to work on a section in 2d, the things get a little exciting for me.
Message 14 of 66
MatthewAd
Message 15 of 66
MatthewAd
I need to get used to it more, I struggle when I use reference models, PDF or DWG, I like to have plans I can work on and then check 3d if everything is ok, old school😀
Message 16 of 66
filip_denolf
for me its the other way around, i'm an AS user for 7 years now, before that i got 10 years of parabuild experience (an lesser expanded program but also on an autocad based program)
Now i need to expand my drawings with concrete reinforcements and started with tekla.
But i found it a very stupid program to work with.
very time consuming for steel.
they told me nobody can use the full potential of the program because its so big.
now i know better, nobody can because they make it so hard to understand it, i could be good but they need to rewrite the interface. (the same of 20 years ago)
i can draw a steel project 4x faster with AS
Message 17 of 66
bigcarl5000kg
Hi @filip_denolf,
super experience 👍👍👍👍
Message 18 of 66
acbsdesign
@filip_denolf
Thank you for sharing.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Message 19 of 66
pinnacledrafting
@MatthewAd ,
Like you, I am also a previous users of other 3D systems. I have used StruCAD (bought by tekla recently), SDS/2, Prosteel, Asteel, and Tekla. All for several years each. While each system has something they do exceptionaly well, no one system is perfect and will give you 100% satisfaction. My reason for switching to Advance Steel was several reasons. 1. The price was hard to beat. 2. The drawings are more customizable and they look great (for the most part).
3. It does stairs and railing better than any system I have seen and I do a lot of stairs/railing.
4. The learning curve is small if you already know AutoCAD and if you come to this forum once in awhile you can pick up on tips and tricks along the way. (I've been using AS since 2007 and I'm still learning things)
I could go on but I won't
In short, give it a chance and you will see what a powerful system it is even though Autodesk hasn't been paying enough attention to development as of late.
Bill
Message 20 of 66
MatthewAd
Hi Bill,
It is true that the price is hard to beat. I just wished the drawing creation was quicker and less clumsy. I am getting better at it day by day so all is good.
