My Purlin plate connections are not working
almir.gustavo
almir.gustavo
I am having trouble to use the connection vault to the purlin plate, it send ths error:"Template values not found. Take defaults of the connection. Entry for this profile cross section not found in table." Thanks for the help
múinteoir
What type of sections are you trying to add the purlin plate too? Usually this error comes from the incorrect beam type
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
almir.gustavo
Im using C section for the purlin and w Section for the beam. I chaned the sections n times and nothign happened, but thanks for the advice
I had similar problem with the connection "Vetical purlin plate"
The image below shows the problem
but i heve no idea of an answer
Error
