hi colleagues.
does anybody knows how to move a stair in a vertical direction?
I have to move 689mm in a vertical direction. I take the box an I move it…
then the stairs seems to be stretched keeping the base plate at the same level..
how can I just move the stair??
Solved by mick-CNF. Go to Solution.
Solved by Karsten_Bork. Go to Solution.
Change your visual style to wireframe and you will see a white box around the stair, this box is what you need to move.
Or use transform elements move and select the joint box for the whole stair.
Move the base plate joint boxes also.
problem is your base plate on stair. The base plate is referenzed on UCS in World.
Delete the base plate and create a new on and AS ast you for reference point this will be the point were your stair is starting.
You will need to alter the base level in the stair base joint macro.
Or delete the base plate, move the stair then add the base plate again.
I had to delete it. then was posible to move in any direction.
thanks a lot
