MOMENT CONNECTION SYMBOL ON GA DRAWINGS
markhubrich
Advisor Advisor
markhubrich
Anyone have a solution besides inserting a block?
...and fix the kiss export issues.
Dias_Antonio
Dear colleague
I did not understand right your question. By the way, you want a moment conection in General Arangement Drawing?
Have you ever tried to create a new object presentation just for this element? A strategy where the moment conection is visible with hidden lines...
Att
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
Sebastian_Eiche
Hmm first thought: maybe a weld symbol?
You could create a new weld type in the databases and call it "moment weld".
After this you could open the weldtemplate.dwg and create the symbols you want.
If you now use this weld type in your model, you use this for showing it in GA drawing
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian_Eiche
the problem is, without customizing there's only a "weld on" or "weld off", so maybe not the best idea.
But with filter or third party tools it's  possible
Sebastian Eiche
