- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Using AS 2019
Thank you for reviewing my post! See attached screen capture for reference.
This is probably an AutoCAD failure, but I am using Advance Steel and would hope there may be a solution. I am developing a Canopy model in front of the main model which I have attached as an Xref. After creating a Model View that has a clipping boundary, the boundary does not recognize the xref. Is there a function in AS that will clip xref's? I noticed this true for all generated Model views. I would consider this a complete failure from Autodesk if there isn't a solution.
AAG
Advance Design
Advance Design
