Model view direction change does not update drawing View
estewart3E8B6
estewart3E8B6
How can I update a drawing view after changing the view direction in the model view without deleting the existing drawing?
johnjmbennett
If you used the in built camera option of model views,  which creates a camera based upon the model view direction, it will flag the view for an update.
if you created the view manually , then you will have to recreate the view.
John Bennett
estewart3E8B6
Thank You for the reply, I used the built in view option. Does not update? I created the drawings at work with a user drawing style that I  added a left view to the style. and did not bring home a updated USER configuration file.
that may be the problem
johnjmbennett
so guess try when you are back with the source config.
if you are doing a cut view from Wooten the camera view, I seem to recall it uses a default style for cut views, unless you select a different one, so it maybe the cut view style is not comparable with the object selection set.
difficult to tell without a drawing etc.
John Bennett
