Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Model Role
3 REPLIES 3
jdk5225g
362 Views, 3 Replies
Model Role
I have seen videos of Model Roles, how to make them and how important they are but what effect do they have? I see some have "beams" for example but some have the "Model Role" box checked and some don't. What effect does this box have? I don't get it.
JK
3 REPLIES 3
Ignus.E
in reply to: jdk5225g
Hi
Model Roles are extremely important. It defines in the Drawing process what Drawing style needs to be used to create the drawing for the selected element. For example it a beam is set to a Beam model role, it will be detailed using that specific drawing style to give you the best drawing output. The Checkbox next to the model role in the beam properties if checked means that the numbering process will also take the Model role into consideration. For example if you have 2 exact same beams (and prefixes is not activated) but one has a model role of Column and the other of beam, they would get different part numbers  instead of the same one.
And additional Model Roles can be created in the Management Tool under Object property Editor if required
jdk5225g
I get it. Big help
johnjmbennett
Model role is part of the solution to drive a drawing style output,  the other part is the model object, a parameter inside the drawing style system that can be used to control the presentation of an object that can be a series of model roles combined under a model object.
also the model object is used to drive the drawing process manager, as part of the detail style map, that when you set a model object, this links to the model role/s and the style used is linked to the model object.
when a process is used to create drawings, the system works though the detail style map and when it comes to the model object, and the style set under that, that is the style associated with the element from the model.
https://m.youtube.com/watch?v=DJfsAUcDrV4
John Bennett
In this video, Stephan Gumpert, Senior Technical Specialist at Autodesk Australia explains what model objects are and how they help filter objects for your presentation in your Drawing Style.
