Part is missing in the model & but I can see in the detail drawing (see attached screenshot).
Any idea how to sort out?
Thanks in advance for any input.
Abraham
Solved by abeeler. Go to Solution.
Could it be a 3D display problem? Tried REGEN3? Is object on a layer that's turned off? Also try the _AstM10ShowAllObjects command. Just some ideas.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Hi @bageseabraham,
Thank you for posting on Advance Steel forum 🙂
Is it somehow a model containing the railing joint "Monowills" ?
And some posts are not visible ?
Best regards,
Emy
maybe an model upload would be great to have a look
Sebastian Eiche
