Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Model Check Issue
6 REPLIES 6
markhubrich
333 Views, 6 Replies
Model Check Issue
It may look kinda cool if you were born around 1970 but what does this mean?
I let it try to fix the error and ran it again then it narrowed it down to this one folded plate. These were kind of a bitch to model the curved ones because the cuts on the top have multiple bevel angles to align with slope of concrete ramps.
...and fix the kiss export issues.
6 REPLIES 6
markhubrich
in reply to: markhubrich
I have attached a small portion of my model.
acbsdesign
Hi Mark,
Tried to use Handle / Id, it is feature named 85B, but it cannot be fixed,
Try to delete the very top cut and re-create.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Hi Mark, as already written, the problem is the contour process, which you're using.
I know this works in the most cases, but in this situation, you could use the "cut on UCS" to cut your plate and then the Model Check will not give any error
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Thanks you guys for your thoughts. I spoke too soon before I actually took a closer look. I guess my original cut was off and I needed to trim a part off.
acbsdesign
@markhubrich
That is so unfair, we want our solution marked.
Just kidding-below is a screenshot of how to identify the problematic feature:-Search, Handle or Id, type 85B.
Search and Handle and ID.jpgThis is your featureThis is your feature
AleckGiles
It is obviously too late for this occasion but in future, if you have a similar plate to model you might like to try this workflow:-
  • Draw a spline around the top edge of the concrete.
  • Double click the spline and choose Convert to Polyline (precision up to you but don't get too carried away).
  • Repeat for bottom edge of concrete.
  • Create Twisted Folded Plate between the two polylines.
You will have a full, one-piece, folded plate following the path with the top and bottom edges matching your concrete in one easy process. No need for any additional features.
Just a thought.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
