I have an AS model with some standard UB's which I drew in Revit, Exported to AS, added some connections, holes and some contour cuts in AS, Exported from AS to a new file and then Synchronised from that file in Revit.
The connections (and their holes) show fine in the Revit model after sync but the holes and contour cuts I created don't get created in Revit from syncing.
Any ideas how to fix this?
I found this article on AS support which seems to suggest this is a known limitation and doesn't seem to suggest that there is any intention of fixing or workaround? https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Beam-c...
