Log below,
Is this normal
We've migrated your customization and settings!
To: Advance Steel 2021 - English
Migration Performed on: 28/12/2020 8:53:31 AM
You can restore the default Advance Steel 2021 - English installation settings by running "Reset Settings to Default" from the Windows Start menu->Programs->Autodesk->Advance Steel 2021 - English->Reset Settings to Default.
Migration Details Profiles
3 profiles migrated
"<<ADVS>>" (current) Items migrated together with profile: Profile Workspace File
From: C:\Users\Quamtum\appdata\roaming\autodesk\advance steel 2020\r23.1\enu\support\profiles\advs\profile.aws
To: C:\Users\Quamtum\AppData\Roaming\Autodesk\Advance Steel 2021\R24.0\enu\Support\Profiles\ADVS\Profile.aws
CUI Files
Main CUI file set to C:\ProgramData\Autodesk\Advance Steel 2020\GBR\Steel\Support\Toolbars\AdvanceSteel_English.cuix
Error
Error encountered migrating CUI file - bim360.cuix could not be found.
Error encountered migrating CUI file - acperfmon.cuix could not be found.
Error encountered migrating CUI file - autodeskseek.cuix could not be found.
Error encountered migrating CUI file - contentexplorer.cuix could not be found.
Error: Access to the path c:\program files\dynamo\dynamo advance steel\2020\dynamoadvancesteel.bak.cuix was denied.
Error: Access to the path c:\program files\dynamo\dynamo advance steel\2020\dynamoadvancesteel.dll was denied.
Tool Palettes 1 ToolPalette catalogs migrated
Migrated from "C:\Users\Quamtum\AppData\Roaming\Autodesk\Advance Steel 2020\R23.1\enu\support\ToolPalette\AcTpCatalog.atc" to "C:\Users\Quamtum\AppData\Roaming\Autodesk\Advance Steel 2021\R24.0\enu\support\ToolPalette\AcTpCatalog.atc".
1 AuthorPalette catalogs migrated
Migrated from "C:\Users\Quamtum\AppData\Roaming\Autodesk\Advance Steel 2020\R23.1\enu\Support\AuthorPalette\AcApCatalog.atc" to "C:\Users\Quamtum\AppData\Roaming\Autodesk\Advance Steel 2021\R24.0\enu\Support\AuthorPalette\AcApCatalog.atc".
"<<VANILLA>>" Items migrated together with profile: CUI Files
Main CUI file set to C:\Users\Quamtum\AppData\Roaming\Autodesk\Advance Steel 2021\R24.0\enu\support\acad.cuix
Plot Files 10 plotters (.pc3) migrated
From: C:\Users\Quamtum\AppData\Roaming\Autodesk\Advance Steel 2020\R23.1\enu\Plotters
To: C:\Users\Quamtum\AppData\Roaming\Autodesk\Advance Steel 2021\R24.0\enu\Plotters\Advance Steel 2021 - English PC3 Files
2 plotters model parameters (.pmp) migrated
From: C:\Users\Quamtum\AppData\Roaming\Autodesk\Advance Steel 2020\R23.1\enu\plotters\PMP Files
To: C:\Users\Quamtum\AppData\Roaming\Autodesk\Advance Steel 2021\R24.0\enu\plotters\PMP Files
13 plot styles (.stb, .ctb) migrated
From: C:\Users\Quamtum\AppData\Roaming\Autodesk\Advance Steel 2020\R23.1\enu\plotters\Plot Styles
To: C:\Users\Quamtum\AppData\Roaming\Autodesk\Advance Steel 2021\R24.0\enu\plotters\Plot Styles
Shapes
3 custom shape files (.shx) migrated
From: C:\Users\Quamtum\AppData\Roaming\Autodesk\Advance Steel 2020\R23.1\enu\support
To: C:\Users\Quamtum\AppData\Roaming\Autodesk\Advance Steel 2021\R24.0\enu\support
