Why when I click on open in AS I get this thin strip ask for a file name. What happened to my file menu box? Someone know?
Solved by Rob_Merriman. Go to Solution.
Hi @josephSQ5UF
I would assume you have had a crash at some point, when this happens there is a AutoCAD default that has changed.
If you type FILEDIA and change the value from 0 to 1 you will get the boxes back.
FILEDIA is File Dialogue and 0 is off, 1 is on.
Rob Merriman, AEC Technical Lead, Graitec
