Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Manual update to anchor DB
2 REPLIES 2
markhubrich
369 Views, 2 Replies
I use Hilti anchors frequently. It seems the database is a little dated. What is the best way to go about updating. I need to manually edit all reference to HY150 since it isn't made anymore. Should I edit the DB to just replace any instance from HY150 to HY200?
...and fix the kiss export issues.
2 REPLIES 2
AleckGiles
in reply to: markhubrich
If you edit existing anchors then old models that get loaded would be affected. Probably best to Duplicate the anchors (right click on the name in the Anchor section of Management Tools) then edit the new copies. The you have both versions in the database.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
markhubrich
in reply to: AleckGiles
Where is the database for the anchors?
