Managment tools do not open
eyal.ch
Message 1 of 13
eyal.ch
Hi All,
I click on the management tools and the icon appears on the task bar but it doesn't open,
the icon as shown is on the task bar but I can't open it,why?
Replies (12)
Message 2 of 13
pendean
Community Legend
Community Legend
is it on a second screen that is no longer in use?
Message 3 of 13
johnjmbennett
Try this AKN, that shows how to reset back to main screen,  I suspect this is what has happened.
https://knowledge.autodesk.com/support/advance-steel/troubleshooting/caas/sfdcarticles/sfdcarticles/...
John Bennett
Message 4 of 13
eyal.ch
Hi @pendean ,
NO, I tried to check all my 3 screens, but I get this:
right click:
but it will not open even when I unpluged the other screen and left only with the laptop screen.
Also, I tried to restart windows explorer with no use.
I can't open it.
What to do?
thank you
Message 5 of 13
johnjmbennett
You need to reset the coordinates for mT in the ASsettings file, as shown on the FAQ link
John Bennett
Message 6 of 13
eyal.ch
Hello @johnjmbennett ,
Sorry but I couldn't find how to reset the coordinates for mT in the ASsettings file.
can you be more specific please.
thank you.
Message 7 of 13
johnjmbennett
Read the Knowledge article , it gives explanation of where the file is and how to edit or delete it.
that file is created  when you open AS for the first time.
John Bennett
Message 8 of 13
Jonathan3891
Close Advance Steel then delete the ASSettings_User.xml, then reopen Advance Steel.
Jonathan Norton
Blog | Linkedin
Message 9 of 13
eyal.ch
Hi @Jonathan3891 ,
where is the XML file, it is not in the software folder.
Message 10 of 13
Jonathan3891
@eyal.ch
C:\ProgramData\Autodesk\Advance Steel [version]\[language]\
Jonathan Norton
Blog | Linkedin
Message 11 of 13
johnjmbennett
You will need to enable hidden files and folders, under windows to see program data, it is not in program files.
John Bennett
Message 12 of 13
eyal.ch
GREAT!! thank you , SOLVED!
Message 13 of 13
suad_kapidzija
A few comments on this thread following my experience in the new(er) version of the software (2024):
1. The file path was as attached in the screenshot below,
2. There is a '-' (negative/minus) sign in front of the coordinates in my case, I thought it was just a dash, but it actually moved the coordinates to the negative side of X and Y axis. After removing the '-' the (100,100) coordinate works quite well
3. In my case the application (AS) did not have to be restarted to see the changes. Just save the file (maybe close it too) and run "Mgt Tools" again, should display the window with updated coordinates
