Hi all
I am trying to change some default setting in the advance steel management tools, but whenever I do this they don't save.
I open the management tools, click defaults, alter (for example) a default Column to something we use more commonly, and click "Load settings in advance", but they don't stay for some reason. Does anyone have any suggestions?
Steven
Solved by Jonathan3891. Go to Solution.
Solved by acbsdesign. Go to Solution.
After that Update defaults:
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
You may lack the permissions to edit items in that folder due to your companies IT policy.
You can check the permissions by going to C:\ProgramData\Autodesk\Advance Steel <YEAR>\<REGION>\Steel and right click on the "DATA" folder and look at the permission tab and see if you lack the permissions required to make edits.
