Dear Experts,
What is this ?
We do these with SQL server long methods
We were trying to do short methods to paste the script directly with management tools Table Editor
We are getting error after pasting
C:\Users\Sanjoy Nath\AppData\Local\Temp
Value cannot be null.
Parameter name: element
PresentationCore
System.Collections.ListDictionaryInternal
at System.Windows.Automation.Peers.UIElementAutomationPeer.FromElement(UIElement element)
at System.Windows.Controls.DataGrid.CellAutomationValueHolder.TrackValue()
at System.Windows.Controls.DataGrid.ReleaseCellAutomationValueHolders()
at System.Windows.Controls.DataGrid.OnExecutedCommitEdit(ExecutedRoutedEventArgs e)
at System.Windows.Input.CommandBinding.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.Input.CommandManager.ExecuteCommandBinding(Object sender, ExecutedRoutedEventArgs e, CommandBinding commandBinding)
at System.Windows.Input.CommandManager.FindCommandBinding(Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.Input.RoutedCommand.ExecuteImpl(Object parameter, IInputElement target, Boolean userInitiated)
at System.Windows.Controls.DataGrid.EndEdit(RoutedCommand command, DataGridCell cellContainer, DataGridEditingUnit editingUnit, Boolean exitEditMode)
at System.Windows.Controls.DataGrid.CommitAnyEdit()
at System.Windows.Controls.DataGrid.OnEnterKeyDown(KeyEventArgs e)
at System.Windows.Controls.DataGrid.OnKeyDown(KeyEventArgs e)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndKeyboardInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawKeyboardActions actions, Int32 scanCode, Boolean isExtendedKey, Boolean isSystemKey, Int32 virtualKey)
at System.Windows.Interop.HwndKeyboardInputProvider.ProcessKeyAction(MSG& msg, Boolean& handled)
at System.Windows.Interop.HwndSource.CriticalTranslateAccelerator(MSG& msg, ModifierKeys modifiers)
at System.Windows.Interop.HwndSource.OnPreprocessMessage(Object param)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
System.Windows.Automation.Peers.AutomationPeer FromElement(System.Windows.UIElement)
We are trying to paste this script in the management tools Table Editor
'Europe2 SAAN SAAGIRID script used by Numbering process
Function getNumber(EqualPartObject)
'We dont use these On Error Resume Next(this is for final releases sometimes)
'we create a text file first d:\testfile.txt
'Const ForReading = 1, ForWriting = 2, ForAppending = 3
Dim fs, f As Object 'we need to check in DPM scripts
Dim the_objects_counter_internal as Double
the_objects_counter_internal =0
Set fs = CreateObject("Scripting.FileSystemObject") 'we need to check in DPM scripts
''' Set F = fs.OpenTextFile("d:\\testfile.txt", ForAppending, TristateFalse) 'this dont work
Set f = fs.OpenTextFile("d:\\testfile.txt", ForAppending)
checkElement = False
Dim strToCheckRole As String
strToCheckRole = Obj.ClassType.Name
Call f.Write(vbCrLf & the_objects_counter_internal & "strToCheckRole=" & strToCheckRole & " " & Str(Now) )
Number = -1
If PositionMarkCreator.MarkProcessType = kSinglePart Then
'Calculate the single part number
PositionMarkCreator.UseTemplateType = kSinglePart
StartAt = PositionMarkCreator.GetStartAtForSinglePartsWithPrefix(EqualPartObject.Type, EqualPartObject.SinglePartPrefix)
Delta = PositionMarkCreator.getDeltaForSingleParts(EqualPartObject.Type)
Number = StartAt
Number = PositionMarkCreator.AddZerosToPartMark(Number)
' NumberWithTokens contains prefix
NumberWithTokens = PositionMarkCreator.getNumberWithTokens(Number)
Do Until PositionMarkCreator.isUniqueInTheModel(kBoth, NumberWithTokens)
StartAt = StartAt + Delta
Number = StartAt
‘Role is string types
Call f.Write(vbCrLf& " FOR LOOP OF kSinglePart & " EqualPartObject Role =" & Role & " " & Str(Now) & EqualPartObject.Type & EqualPartObject.SinglePartPrefix & ( StartAt+Delta) & "IS STANDALONE = " & EqualPartObject.Standalone)
Loop
'Update the kernel by the number in order not to start the next time again
'from original startAt
' Ola: # 13323: because of speed pbs, i decommented this line
PositionMarkCreator.UpdateStartAtForSinglePartsWithPrefix EqualPartObject.Type, EqualPartObject.SinglePartPrefix, StartAt+Delta
ElseIf PositionMarkCreator.MarkProcessType = kPreliminaryPart Then
'Calculate the preliminary part number
StartAt = PositionMarkCreator.GetStartAtForPreliminaryPartsWithPrefix(EqualPartObject.Type, EqualPartObject.PreliminaryPartPrefix)
Delta = PositionMarkCreator.GetDeltaForPreliminaryParts(EqualPartObject.Type)
Number = StartAt
Do Until PositionMarkCreator.isUniqueInTheModel(kBoth, EqualPartObject.PreliminaryPartPrefix & Number)
Number = StartAt
Call f.Write(vbCrLf& " FOR LOOP OF kPreliminaryPart & " EqualPartObject Role =" & Role & " " & Str(Now) & EqualPartObject.Type & EqualPartObject.SinglePartPrefix & ( StartAt+Delta) & "IS STANDALONE = " & EqualPartObject.Standalone)
Loop
PositionMarkCreator.UpdateStartAtForPreliminaryPartsWithPrefix EqualPartObject.Type, EqualPartObject.PreliminaryPartPrefix, StartAt+Delta
Else
If EqualPartObject.IsMainPart Then
'Calculate the main part number, it’s a main part
PositionMarkCreator.UseTemplateType = kMainPart
StartAt = PositionMarkCreator.GetStartAtForMainPartsWithPrefix(EqualPartObject.Type, EqualPartObject.MainPartPrefix)
Delta = PositionMarkCreator.getDeltaForMainParts(EqualPartObject.Type)
Number = StartAt
Number = StartAt
Call f.Write(vbCrLf& " FOR LOOP OF IsMainPart & " EqualPartObject Role =" & Role & " " & Str(Now) & EqualPartObject.Type & EqualPartObject.SinglePartPrefix & ( StartAt+Delta) & "IS STANDALONE = " & EqualPartObject.Standalone)
Loop
PositionMarkCreator.UpdateStartAtForMainPartsWithPrefix EqualPartObject.Type, EqualPartObject.MainPartPrefix, StartAt+Delta
End If
End If
f.Close
getNumber = Number
End Function
