how do you make a single part drawing from a special part?
I have many projects which require rolled parts, the main issue is the wire mesh panels.
As advance steel won't curve 'grating' I make a special part of curved wire mesh eg pic-01.
works fine on the assembly dwg and GA's but I can't figure out how to make a single part dwg of the special part in my project.
the graitec help page https://graitec.com/uk/resources/technical-support/documentation/technical-faqs/faq-2392-how-are-sin...
Appears to make a separate dwg with manual dimensions so no link to assemblies or bill of materials?
Solved by Tomislav.Golubovic. Go to Solution.
