Macro Boxes
Macro Boxes
Tony_Gibbs
Macro Boxes
Tony_Gibbs
Is it possible highlight all the Macro boxes that belong together so I know where they are as it gets hard to remember all the macro locations
ChristianBlei
give the joint (group) a unique name and create and use a search filter for joint using the joint name (and to narrow the search but not necessary if your joint name is unique) joint type.
HTH,
Christian Blei
Christian Blei
CBT Christian Blei Tools
christianblei.de
youtube.com/channel/UCxjA_NbeScQy9C0Z1xjwXpw
Emanuel.Nestor
Autodesk Support
Autodesk Support
Hi @Tony_Gibbs
Thank you for posting on Advance Steel forum 🙂
Please let us know if you managed to use the Search Filter to mark the grouped connections.
Also, you might want to consider voting for this idea:
Best regards,
Emy
Emy Nestor
