Line thickness in plotted PDFs is thicker than desired ADVANCE STEEL
U3213370
U3213370
Line thickness in plotted PDFs is thicker than desired.I am seeking guidance and suggestions from the community on how to resolve this issue. If you have encountered a similar problem or have expertise in Autodesk Advance Steel, please share your insights, solutions, or troubleshooting steps that might help me correct the line thickness in my plotted PDFs.
robertwmerriman2
Hi @U3213370
Line thicknesses and colours are controlled by the CTB file which is setup in the page setup manager
This page explains where these options are and how to change the thickness - https://advantage.graitec.com/en-US/knowledgebase/article-details/?code=KA-03132
The colours that are used on drawings are controlled in the management defaults, if you expand Drawing Presentention you will see colours
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
Sebastian_Eiche
the details which are located in the layout tab are not showing the line thickness...you need to activate the lineweight:
You also could deactivate the lineweight in PDF (for having a better view) just press CTRL+5
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
sdonohoedesign
If you use the standard 'out of the box' AS presentation / colours, then you might find the attached .ctb file helpful.
The drawing presentation using the standard .ctb file is extremely poor.  Lines are far too heavy, and it is extremely hard to read drawings.
