Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Level Symbol Modification
2 REPLIES 2
806 Views, 2 Replies
I'd like to modify the level symbol to look as our company standard. I've been unable to get the elevation to move under the line, and add an attribute above. We're already using the prefix for the EL =. Anyone know how to modify this further?
2 REPLIES 2
chrisengg
Go to Symbols folder and save original Heightkote dwg in a separate folder or rename it in same folder.Now you can modify heightkote dwg to get the type you are looking for.The datum point of insertion is 55mm away from point of triangle of level.You will require to do some trial and error work to get exact placement
in reply to: chrisengg
@chrisengg Thanks for your helpful suggestion.
