if you are on about the Truss macro, there is an option inside the macro to move all the lacings so they do not intersect, or required a compound cut. on the "Web offset Tabs top and bottom, you will fine drop down for exact cut setting and a check box to move system line, entering a value in the box will allow the movement of all the lacings the same values on which ever boom you select.
Alternatively there is an exterior option to move the diagonal lacing across, by a given amount. This is on the Features palette, Called "Beam Clearance" select the bottom boom first, then the vertical lacing, then diagonal lacing, enter the offset, and the individual lacing moves across.
John Bennett
