Dear All,
I used the drawings style - 3d view -object selected - w/0 Lables
once the drawing generated , i tried to give labeling , but instead of section name Main part mark only comes. I dont need main part mark , i only need section name. Please refer the attached snaps accordingly . Please advise
This functionality is controlled by "Tokens". In the list of Tokens, choose the option "Part Name" and it will automatically pick up on the section name.
Refer to the attached image for clarity.
You can also change the token semi-permanently when doing manual labels....
1. Start "insert label" command>enter the letter "C" to edit content definitions>for the beam, plate, etc.-expand the entity and replace the token the is defaulted.
2. You can reset this back to the defaulted token if needed.
