Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Label/Token
1 REPLY 1
milica_milosevic48
144 Views, 1 Reply
Label/Token
Please find a screenshot below that shows a problem that I have.
When I try to create a cut view the label is merged and it is not correct. AutoCad seems to be merging several elements into one description although these elements are completely different. Can someone please help me resolve this issue.
Thank you in advance,
1 REPLY 1
Just a quick observation. the token seems to be misspelled as there is no 'm' at the end of %SinglePartPosNum in the token showing. Adjust the token and renumber the model then update the 2D if this is still an issue. Hopefully this will help.
