Question: Where can I find a list of the Autodesk Knowledge Network support solutions that were created and/or updated in the month of July?
Week One:
Advance Steel: How to add a new material for anchors
Advance Steel: New BOM template on general drawings for the bolts shows incorrect quantities
Advance Steel: Some red points that do not exist in 3D model appear in detail drawings
Week Two:
Advance Steel: How to configure by default a ; (semicolon) instead the , (comma) for TXT file BOM ex...
Advance Steel: Traverse section for the connection “Base plate with traverse” (GroundingJointBolted)
Advance Steel: visualization folded plate on drawings
Week Three:
Advance Steel: Angle (orthogonal) tolerance for holes leads to incorrect DXF file
Advance Steel: Changing titles of revision table columns
Week Four:
Advance Steel: Differentiate between workshop and site screws in main part drawings
Advance Steel: How to add custom bolts
Advance Steel: Problems to delete items / position numbers for single parts and main parts
Advance Steel: Side Rails Outside connection joint error message when try to use it
Week One:
Week Two:
Week Three:
Week Four:
