Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
is not Connection vault editable? after it has done
1 REPLY 1
amg.monaco
235 Views, 1 Reply
when after closed connection vault window,
can not change its properties?
1 REPLY 1
alickomay
in reply to: amg.monaco
not shore wot u needing  but
u can open conection valt form buton in home tab
u can customize it a bit  by cliking on the "gear" icon at top of vault
if u made a joint with sumet from conetion vault u can get back to the propertys of that conection by rite cliking  on part of the joint "as in a bolt , a plate  just not the atchel beams that the conection is on " and select advance joint propertys
