I have the same problem with this identical parts.
I have two identical plate and after numbering I have two different single part.
Tolerance value from default named "Tolerance for identical parts identification" I set 0,6 .
Attached is dwg with these two plate so you cab see what is the problem.
Thank you in advance.
