Identical parts with different mark numbers
tonilipovac
tonilipovac
I have the same problem with this identical parts.
I have two identical plate and after numbering I have two different single part.
Tolerance value from default named "Tolerance for identical parts identification" I set 0,6 .
Attached is dwg with these two plate so you cab see what is the problem.
Thank you in advance.
Sebastian_Eiche
How do you create the plates?
If I use the control command for the difference between two object, I get the information: Difference in geometry. If I create singlepart details of the plates, all look the same, but the round contour is one time dimensioned and one time not (I move the details to overlay them):
So by zooming to the contour in the detail, it looks, like the contour is maybe copy from one to the other plate but the UCS was maybe a little bit rotated by doing this?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
tonilipovac
Hello Sebastian,
I do not now exactly how I create these plate but I have two scenarios:
1.) I have once create plate and then I mirror her to another position.
2.) I have create once plate with all contures and then I copy these contures to another plate (with mirror or just copy with advance copy option.
Sebastian_Eiche
Hmm if I copy the plates and do a numbering the plates get the number from copied original one
Sebastian Eiche
ChristianBlei
I also had a look at your plates. Copying them or mirroring them result in identical plates. So the process of copying the features has to be the reason as Sebastian already asumed. I also looked at the features of the plates. My advice is to find simpler ways to create the plates. Start with a polyplate whose contour is close to what you need and then use necessary notches. Each of your plates has 44 features....most of them are just erasers for leftover plate parts....
HTH,
Christian Blei
Christian Blei
CBT Christian Blei Tools
christianblei.de
youtube.com/channel/UCxjA_NbeScQy9C0Z1xjwXpw
