Hello, I have this problem, it has never happened to me.
I have a beam assembly with the same connection plates, and AS detects that they are different and assigns them different cut names.
When I only have the front view the cuts are assigned correctly, but when I add the top view, an additional cut is attached.
Hi @javiervega10,
have a look in Management Tools / Defaults, here is a setting to recognize and apply the same cuts.
HTH
Hi @javiervega10,
HTH
Yes, I have it activated, that's why the A-A cuts on the right are detected, only the first one on the left does not detect them the same, they are the same plates, same inclination, same beam.
The only thing I think it could be is that the beam in that connection is located to the right of the plate, and in the other connections the beam is located to the left.
I have also modified tolerance for identifying equal cuts and it remains the same
Hi @javiervega10,
when you add the top view manually in the drawing (via manual cut with matching view definition ) , will cuts be generated differently?
Hi @javiervega10,
I see different part numbers for stiffiners. Renumber so the web plates are the same part number if you can. Otherwise, they are different so you'll get another cut section.
It could also be possible that the difference between A and C sections since the part marks are the same is the welds that are not shown.
