How to Toggle Green frame on model
Cjohnston
Cjohnston
Beginner to Advance Steel. Was curious if there is a way to turn off the green frame that comes up when cutting an object.
Attached is a picture of what I am talking about.
Thank you in advance.
nferrellP7XMX
double click on your steel profile, go to display type and change to standard.  cuts should be removed.
adkstorm
What do you mean by steel profile? ...you mean Management Tools?
Sebastian_Eiche
no he means the profile (for example a pipe) itself.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
jonathan.kayTBWKR
Community Visitor
Community Visitor
I know this has been addressed, but changing display type to "standard" did NOT make my green cut marks go away at all. I found a work around for that. Click on the green cut marks, then right-click and select "properties". In properties menu, select "transperency" and change it to 90 or 100. When you regen, the green lines will vanish!
mwwm
Or try to use selection + selected object off (in quick views tools palette).
AleckGiles
The green shapes are all features. These can be part of a beam or a plate or grating. If the parent object (beam, plate, or grating) is set to Display Type "standard" in its properties the green shapes will be hidden. Set the display type to Features to show them again.
Changing one beam will not affect other beams or plates etc.
To hide all green shapes the quickest way is to use Selectin Filters > Beams, followed by Quick Views > Standard Presentation. then Selection Filters > Plates followed by Quick View > Standard Presentation. All for the palette.
Alternatively, you could do Selection Filters > Beam Features, Quick Views > Selected Objects Off, Selection Filters > Plate Features, Quick Views > Selected Objects Off.
Both methods amount to the same thing.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
