IFC Export doesn't work properly
leo.tavakoli
leo.tavakoli
Hi all,
I tried to export my Advance Steel model to IFC format. The problem that I encountered is that as you can see in the pics attached, some connections become corrupted. As you can see the connection plate changes position in the exported file, etc.
Do you guys know what should I do to get an accurate IFC export?
Best Regards,
Leo
Sebastian_Eiche
could you have look, how far your model is located from WCS 0,0,0 ?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
leo.tavakoli
Hi Sebastian
It's right on the spot. WCS is located at the intersection of grids G and 1.
Leo
Sebastian_Eiche
do you double check it with another viewer? Maybe the issue is just appearing in this viewer?
Sebastian Eiche
mick-CNF
@leo.tavakoli  what connection are you using for the column and rafter?
If this information solves your problem please accept as a solution.
leo.tavakoli
Hi Sebastian,
I opened it in other viewer programs and the problem persist. My intention was to export the advance steel model into a revit file. I found that using the revit export extension (which uses .smlx format) doesn't work properly as it fails to export plates. It failed to export any of my columns and rafters which are in fact created as a tapered beam and also any of stiffeners and base plates.
The other solution that works better for me is to export the A.S model as ifc format and then import it into revit, Which in this case some connections become disfigured. The problem with the IFC export is that it cannot recognize some of the polygon cuts and the member is shown as uncut which results is being disfigured.
Best Regards,
Leo
leo.tavakoli
Hi Mick,
I have used and End Plate connection with some extra plates that I created manually.
Best Regards,
Leo
