How to show a Child Dialog from Joint.page dialog (API)?
I need to show a Child dialog from Joint dialog, but it seems not work. Dialog frame is show out, while context does not show out, it keep running. Does anyone know why? Is there a limit in API?
Code are something like:
at IRule:
public void GetUserPages(RulePageArray pagesRet, PropertySheetData pPropSheetData)
RulePage rulePage1 = m_Joint.CreateRulePage();
m_Page1 = new Page1(this);
rulePage1.hWnd = m_Page1.Handle.ToInt64();
pagesRet.Add(rulePage1);
at Page1:
private void mouse_Click(object sender, EventArgs e)
  UserForm add = new UserForm();
add.Show(this); // method A
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(Autodesk.AutoCAD.ApplicationServices.Application.MainWindow.Handle, add); // method B
 Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog(Autodesk.AutoCAD.ApplicationServices.Application.MainWindow.Handle, add); // method C
// I tried 3 methods (A, B, & C), none of them works.
Please help if anyone know about it.
Luke
vlad_pavel
The joint dialog does not support adding pages with child pages. If you want to open another dialog from the joint, you should close the joint dialog and then use the autocad api to display it
Vlad
Vlad,
I am not adding child pages to joint dialog, I need to open a dialog from there. For example, I like to open a dialog for perferred profile, available plate thickness (per customer), or list of materail (per job)... or even quick help window to explain meaning of input. It can be modal or modaless.
I see one of joint "Hanuch Bolted" have a "Edit" button, which open a new dialog when click it. That is exactly what I need. Anyone know how to do it correctly? See attached snap shot.
Luke
vlad_pavel
When you pass "this" to "show" function, you are displaying a dialog as a child window of the joint page. I have created a new windows form with some controls and display it from the joint page.
Form1 f = new Form1();
f.Show(this);
I used the SampleJoint from the SDK to do this
It worked fine, maybe your UserForm or the joint page has something different
Vlad,
I tried same, but not work. See my code on first post.
Maybe it's due my code in dialog form. Same code works if I start is from Advance Steel command, or window, but failed when start from Joint pages.
Luke
