this is the online help pages to label Strategies, if you review this you will see how the are intended to work.
The basic two concepts are "By angle Method" and "By Area"
Angle type is based upon rotation.
Area is based upon position , top bottom left right
Distance controls the proximity of the label to the body/element being labelled.
The type of label is controlled relative to the model object defined in the drawing style line, this can be genralised one like Beams, or a more specific element type based around a model role within that element type Element Beam, model role Column, as an example. similarly model objects can be used to group a series of model roles into one collective group to apply a common label type too, example columns can have several model roles column, corner column, door posts.
both methods do have lot of options, but look for one by angle, i know we use one fro plan and set it to be at 45 degrees for columns. so i would guess you need to create one for 0 degrees, There is a tick box option to align with section/beam also "along beam"
online help.
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU...
i am not sure you will fine the full solution, but we do manage to achieve some reasonable success with out labels.
its not perfect by any means, but you can achieve something, i imagine this is a very difficult area to control via programming.
John Bennett
