How to overlap the plates over the given curved beam?
arunvivinjoe
arunvivinjoe
I want to create a cladding plate over the curved beam.Dwg file was attached here with.Plates are placed c/c over the beam.
johnjmbennett
try this :
https://graitec.com/faq-item/faq-2428-how-is-a-cladding-sheet-defined-on-a-curv/
John Bennett
arunvivinjoe
I can't able to understand the concept mentioned in the above link, can you please explain me with some small demo video?
AleckGiles
You cannot curve cladding sheets across their width.
If you want the curve along hte length of the cladding sheets then:- Draw your curve, use Beam from Line on the curve and select the cladding profile you require as the section type. Cladding or anything else is just a curved beam like any other.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
