how to insert a beam , align to ucs
alickomay
alickomay
how do u make a beam  that is lined up to the ucs
this used to be easy  just make a beam , make shore f8  , ortho on
but now it lines the beam up to what ever i click/snap to
acbsdesign
Turn 2D snap on and off and Polar tracking ON (F10)?
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
alickomay
triyed that had no effect
all so i put a beam in, it line's up to  stringer
i delete beam
re insert beam exactly the same way as first beam and it works , aline to ucs
so its definitely got sum randomness to it
ArjunGaba
@alickomay  No need to turn 2d snap and f10. Please click option and turn on replace z value . Align ucs to any line or object by using ucs command than place member . It will work .
