how to create threaded rod with two bolts and nuts?
egidijus_drafting
egidijus_drafting
hi All,
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Sebastian_Eiche
in general you had two options:
  • use an anchor
  • use a round bar (could be renamed it the database to threaded rod) in combination with specialparts
Both ways have their advantage, if you need a singlepart detail, the second way is needed. But if m you want to have the the threaded rod in the same material list like bolts and anchors, you need to change the bom template a bit.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
egidijus_drafting
I have created a basic version of special parts, but I was hoping for a more advanced solution that allows options to change the rod size, length, etc.
Yes, I want the rod, nuts, and washers to be displayed in the BOM on the assembly drawings. Currently, I have used a 'dummy' weld to achieve this, although I am not sure if this is the best method. I couldn't find any information online to achieve this in a better way.
Sebastian_Eiche
for my point of view, this is the best way, maybe another user will have a different view to this topic. You could combine the parts by using a custom connection (for example beam end)
Sebastian Eiche
egidijus_drafting
Let me simplify the question:
What are the steps to create a threaded stud with 2 nuts and 2 washers that also appear in the BOM? (I have no problem attaching it with a ‘dummy’ weld to include it in the assembly drawing).
Lewk_SGS
Create a custom user section for the threaded rod by following this help article:
Help | Create and Define a User Section | Autodesk
Then you can create the threaded rod to be as long as you want, just like any other beam/shape. Then yes, you can use a "dummy" weld to attach the washers and nuts (I recommend using these as special parts). Doing this, all of the parts will show up in the BOM both on and off the drawing. Be sure to specify the material used for the threaded rod in its properties, otherwise the weight and other information may be off if the default material is used (if that is a concern for you).
I've done this countless times for anchor rods, epoxy bolts, and other rod/nut assemblies.
Also, take care when you create your custom user section and naming it. Removing a user section from Advance Steel is a bit of a chore if you mess up!
Lewk_PSB is an old account that is owned by a company I no longer work for.
If this reply answers your question, please "Accept as Solution" - Thanks!
